How do I adjust my cab door ?
Ponvanman
Post by Ponvanman »
[/[URL=http://s1087.photobucket.com/use ... .jpg[/img]url]
As can be seen from the photos the cab door is catching at the back. I have looked at the adjustment threads but cant seem to make sense of what i need to do ? There seems to be a good gap at the front edge, it just needs moving along a tad. I cant see that there has been any previous work on the A or B posts ?
Many thanks
Ponvanman
Re: How do I adjust my cab door ?
Post by Ponvanman »
Any ideas, tips from anyone ?
markp
Post by markp »
People have not replayed I guess as it's so hard to explain buddy
I'll pm you my number and I'll chat you though it
Markp
Post by maddison »
small movements...
undo the 4 screws on each hinge and knock the hinge in towards the bus...moves the door back
move the hinge out away from the bus...moves the door forward
if that doesnt give you enough change...more extreme but crude adjustment technique...
mallet handle between the hinges and gently open and close the door...moves the door forward
open the door fully, and gently rock on the hinges...moves the door backwards
combination of the upper and lower hinge twists the door either way to get a straight edge etc....
basic and crude, but thats the basics
Reuben
Post by Reuben »
Same problem with mine, taking out the Monkey Dubs seals helped though - amazing how much displacement new seals can cause.
1966 21W Samba resto
Ponvanman
Post by Ponvanman »
Thanks for the suggestions, i'll give it a (gentle) try :)
