Flat 4 Banjo wheel/ CE steering column.
hopper van
Post by hopper van »
Fitting a CE rack and pinion conversion and wanted to fit a Banjo steering wheel.
But, CE said they don't fit their columns very well, and they know of one boss coming off!
Too short over the splines, I believe...
Does anyone run this set up, who can comment on this, please?...
Start with a budget, finish with a mortgage!...
My build viewtopic.php?f=8&t=99481
leebeardsley
Re: Flat 4 Banjo wheel/ CE steering column.
Post by leebeardsley »
Hi there any feed back from this as i want to run the same set up 8O
hopper van
Nowt yet... :roll:
Iroc-2
Post by Iroc-2 »
Hi, I'm running that set up and the only thing that is a problem is the play in the steering wheel, about an inch. I've tried different bosses but to no avail. I would be interested in if this is a common thing or just my set up. Saying all that its not a major problem and I am quite happy to keep the banjo wheel.
