Gear rod connector
Chrispduck
Gear rod connector
Post by Chrispduck » Fri Jun 07, 2019 4:29 pm
Can enyone recommend a gear rod to gear box coupler I was going to try the orange urethane empi one? Thanks
Re: Gear rod connector
Post by ted698 » Fri Jun 07, 2019 9:19 pm
I used the Wolfsburg West one.... there are some shockers out there... the Brazilian ones are sh1te.
Post by vwJim » Fri Jun 07, 2019 11:00 pm
Rule of thumb, if it has EMPI written on it = crap lol...
WW are fine
Chrispduck
Post by Chrispduck » Sat Jun 08, 2019 3:03 pm
Right o thanks
Post by type21f » Sat Jun 08, 2019 3:27 pm
However the EMPI braided throttle cable improved my throttle feel..and combined with two external throttle springs and a Karl_F roller throttle fitting has totally transformed my accelerator pedal response.. My butterflies now snap shut on my 40s!
Only EMPI item I would say proves the rule as above!
Post by JonnyCJ » Tue Jun 11, 2019 2:05 pm
With you on that G - have exactly the same set up albeit with a CSP bell crank linkage.
