Exhaust outlet damaged / Heat exchanger gives heat when shut off.
splitintwo
Post by splitintwo » Mon Jul 16, 2018 10:06 pm
Damaged the exhaust last year the tail pipe got forced out when I backed up too close to a hedge bank.
I don't have a picture but when I refit the tail pipe it's really sloppy and there is enough room to fit a sleeve of the same thickness around it. So judging by pictures on the net and also the hole is flush with exhaust I think I've lost outlet connector (short flared tube)
Can I get one and how is it fixed, looks like it was pressed together at manufacturing.
Its a Ernst single outlet.
I also get heat from the exchangers with the knob turned off (Btw tried both ways just to make sure and its hotter)
could this be due to the flaps not closing properly - can I modify? or somehow use fire retardant sealant? anyone had the same problem?
as this is close to the exhaust, thought I'd try and tackle this issue ... As DAMN it gets hot on a hot day
OHH while were at it, it the exhaust rattles and vibrates on the bumper if I fit the lower (slot type) bolt support on the exhaust, its always been an issue and before I damaged it.
*it came home.. and it went and it hasn't come home again... and probably wont come home for a long while PLEASE STOP SINGING ABOUT IT!
Re: Exhaust outlet damaged / Heat exchanger gives heat when shut off.
Post by vwJim » Tue Jul 17, 2018 6:18 am
Have you tried adjusting the cables? Sounds like there too tight so the flaps aren't closing or the return springs are missing.
Post by 8 8US » Tue Jul 17, 2018 6:59 am
As Jim says, or the cable is getting snagged, disconnect the cables at the heat exchanger end and see what movement you get on the arms.
1960 Single Cab Pickup (resto thread - https://www.ssvc.org.uk/phpbb/viewtopic ... 8&t=122082)
1966 Devon
BJ1
Post by BJ1 » Tue Jul 17, 2018 7:12 am
If you lost the short outlet pipe, then the clamp would have gone with it. Three options Ben
1 Go back to hedge bank and find the bits, then weld it back on.
2 Find an old exhaust and chop off the pipe, then weld it back on.
3 Buy a new exhaust and clamps
Treaslake have a welder - shouldn't take more than five minutes.
1966 Westy in Velvet Green - being restored
1967 Sundial from Idaho
1971 Westfalia from LA
splitintwo
Post by splitintwo » Tue Jul 17, 2018 11:08 am
Ahh thought there was a piece missing on the exhaust, ok I can sort that, I did hope there was something online.
Regarding the exchangers I'll disconnect the cables and see if the flap shuts anymore I doubt it and the all springs etc was fitted at the time. Thought the issue maybe as they are repro ones,I didn't buy them they came with the parts.
any ideas why the exhaust hits the bumper irons? every thing is stock, new exhaust at the time, 3 piece ETC. I'll get a picture up when I refit
Thanks guys
splitintwo
Thanks guys
Post by vwJim » Tue Jul 17, 2018 8:53 pm
Repro parts
splitintwo
Post by splitintwo » Fri Jul 20, 2018 4:46 pm
Yes one spring has gone missing, and also the cables don't reach so I remember fitting them right on the limit with the flaps arm under tension.
Can't think of a way of avoiding this.
Post by 8 8US » Sat Jul 21, 2018 5:26 pm
You could replace the cable or cut them a little shorter and extend each side with a length of bicycle brake cable and an electrical chocblock type connector?
1966 Devon
