Surrey/Collect VOWO Worktop and DIY tools
If it's not bus related and it's for sale post it here.
mattp
Post by mattp » Fri Mar 16, 2018 6:28 pm
Guys,
Clearing out the garage to make way for my van, most items bought new by me, so one careful owner since new. Collection from Leatherhead in Surrey (J9/M25)
PM an Email or post replay with your Email if you would like pictures (and please let me know which items).
Bits for the garage or workshop (see below for DIY)
Fiac 3/150s compressor bought new by me, their top of line with 10yr underwritten tank and 2 years on site maintenance. Comes with custom build cage and wheels (pneumatic tyres), new Clarke air ratchet and impact gun, used DA, air blower, needler, air cut off saw, leads, paraffin gun, water trap. It has done little work, has been used to paint 3 cars and run some air tools -wasn't used with blast cabinet below as the cabinet was installed in a friends workshop and he has already had a compressor. £550 (new £755+cage+tools). NB this is the higher output 14.5 CFM model
30kw Diesel / Kerosene / Parrafin heater with temperature control, light use (last used 18/3/18). Comes with 2Nr 25L containers to buy your fuel in £160
Grease gun. New boxed laser model 500cc capacity 10,000PSI gun, comes with 3 new tubes of grease £15
Snap on long nose pliers £15
Now, if you are building a house you might be after the following
110v loose extension leads £6
110v extension reel £15
110v Defender 2d light £15
110v Defender LED (2D style) light £20
110v 4.5" DeWalt Grinder and mortar chasing attachment. Used once for restoring a brick bay. £45
240v Numatic wet van £35
Black and decker 536 workbench £20
Spiked roller for applying self levelling to flows. Used once, as new £10
mp
Re: Compressor / Blast cabinet / tools / Ammo boxes / Roll cab VOWO
Post by vwJim » Sat Mar 17, 2018 9:04 am
What's the internal space / door opening size of the blast cabinet?
Supplying quality in house designed items plus parts from SCAT, Kennedy Clutches, CB Performance & FIRETEC. Also fitting service including modifications & mechanical upgrades.
mattp
Re: Surrey/Collect VOWO Worktop and DIY tools
Post by mattp » Mon Mar 19, 2018 2:37 pm
mp
