SOLD
ricvw
SOLD
Post by ricvw »
64 walk through sundial a bit unusual as the conversion was done on a factory 11 window kombi most sundial are done on panel vans, I purchased the van in 2007 from the state's i also had a engine built by Pat Downs from CB performance which was fitted by Rust Box along with some other work,
So the bus is currently running on a straight axle conversion out back, a stock beam and dropped spindles with csp disk brakes (the steering box has been raised and the chassis notched when it was running very low).
Mostly original paint the only welding it has ever needed was the sill under the side doors which has been done to a very high standard by one on one, the rest of the bus is solid with no welding needed,the cab floor,battery trays are all original, the engine is a 1955cc with 40dells i have the full spec which I can send you,
Inside there is a full width rock and roll bed a buddy seat and cool box with a draw on top, on the side opening door there is a sundial table, also it has the sundial awning which is even colour matched to the bus. The fabric on the back seats is as close to original as you can get. The interior panels are original the headliner is in really good shape but around the Windows looks a bit worn, the front door cards are looking a bit tired as well. I have the original sundial Windows and inner surrounds which will be included in the sale, the van had all new rubber seals fitted when I bought the van, it has also had a new steering box and cut down to the correct length for the steering box raise.
I also have a 2inch narrowed beam which could also be included in the sale. There is loads more i could tell you if you are interested. I'm located near Clitheroe BB7 price £25000 07917421472
ricvw
Re: 1964 sundial walk through
Post by ricvw »
ricvw
Post by ricvw »
ricvw
Post by ricvw »
ricvw
Post by ricvw »
Stephbong
Post by Stephbong »
If you decide to sell your awing apart ;-)
kai
Post by kai »
Do you have any interior, cab, floor pan, engine etc?
Thanks Kai
ricvw
Post by ricvw »
Pm me your email and I will send them over
kai
Post by kai »
PM sent
Post by flatbeat »
That's a lovely straight bus mate and a good price. Glws
