Early Gear stick
Vinda76
Early Gear stick
Post by Vinda76 »
Does anyone have a pre 59 straight gear stick they would like to sell? I'm after the stick, spring, spring housing and reverse lock out.
Any help would be greatly appreciated.
Cheers Gav
dougall up
Re: Early Gear stick
Post by dougall up »
What is the difference through the years ? I,ve got one I bought and it does not fit a 1966. is this an early one ?
its to short where the spring and housing fits .
Doug
Vinda76
Post by Vinda76 »
Hi Doug,
I'm no expert, however, early gearstick was located closer to the seat, so had a straight stick. The ball is smaller than later ones (16mm? compared with 21mm?) with no locating bar (the part that stops later sticks from rotating).
Gav
galiform
Post by galiform »
Sent pm bud👍
Vinda76
Post by Vinda76 »
Thanks, but haven't received a PM mate
BJ1
Post by BJ1 »
Pretty sure I have a couple of these. pm me for details.
1966 SO42 Westy in Velvet Green - on the road at last!
1967 Sundial from Idaho
1971 Westfalia from LA
BJ1
Post by BJ1 »
Look like you need a straight stick, 16mm ball, no locating pin. Mine are 22mm balls with locating pins so won't fit.
