Heat Exchangers, Heater Pods, Pipes & early Clutch Arm spring
Post by 8 8US » Mon Feb 11, 2019 8:50 pm
Looking for a few parts for the build up of my SC.
Heat Exchangers
Heater Pods
Pipes connecting HE to HP & pipework
Clutch Arm Spring off a small nut gearbox
Photos by PM, already got a couple of rusty sets of HE/HPs so good condition OG ones please.
Alternatively know anyone that can fix this?
1960 Single Cab Pickup (resto thread - https://www.ssvc.org.uk/phpbb/viewtopic ... 8&t=122082)
1966 Devon
Rocket Ron
Re: Heat Exchangers, Heater Pods, Pipes & early Clutch Arm spring
Post by Rocket Ron » Mon Feb 11, 2019 9:09 pm
Got loads of little bits RICHARD if I can be of help.
Ron
Sometimes when you have set the benchmark, the only one you have to beat is yourself !
Post by 8 8US » Mon Feb 11, 2019 10:35 pm
Ron
Thanks Ron, have sent you a PM.
1966 Devon
Re: Petrol Tank, Heat Exchangers, Heater Pods, Pipes & early Clutch Arm spring
Post by type21f » Tue Feb 12, 2019 10:04 am
Send me your wanted list by PM Rich
Post by vwJim » Tue Feb 12, 2019 10:44 am
You'll need early pods for the SC, and then if you use later heat exchangers you'll have to jump up the pipe size.
I've got the tank out of my 56 if you're interested. Or I know a later tank with a sender hole that has been powder coated but has a tiny hole that needs a quick repair.
Post by 8 8US » Tue Feb 12, 2019 12:26 pm
What do you want for the 56 one Jim? Looks like someone cut a sender hole in mine and fitted a guage, so may be interested in the later one instead, how bad is the hole?
1966 Devon
Post by vwJim » Tue Feb 12, 2019 12:55 pm
The later one weeps fuel, so its got to be only a pin hole. I think the owner wants £100 for it.
Mine, £50
Post by 8 8US » Tue Feb 12, 2019 4:11 pm
Mine, £50
Thanks Jim, can you put yours on hold for me? I've got to drop mine into a company near me as they think it can be repaired, if not I'll have it.
1966 Devon
Post by vwJim » Wed Feb 13, 2019 1:08 am
Sure.
