Dual circuit master cylinders and servos
jon parker
Post by jon parker » Fri Mar 30, 2018 11:06 am
Hope no one minds me starting a fresh thread I don't think there is anything current.
My 1964 bus has always pulled to the left when braking, many piecemeal attempts have failed to find the cause (replacing slaves mostly). I have decided to replace the master cylinder and all the pipes, not a bad thing to do anyway. I am inclined to go dual circuit, but read that this might make fitting a servo at a later date more complicated. Anyone got any thoughts on this ?
Would it be better to stick with a standard (single circuit) to make life easier when adding the servo, perhaps I'll put in dual circuit and press harder !
jon parker
Re: Dual circuit master cylinders and servos
Post by jon parker » Fri Mar 30, 2018 11:14 am
Just noticed VWjim's (2012) dual circuit servos amazing thread. Knew I'd see something. I'll check it out....looks like it's starting to add up...in many ways ! You thoughts still welcome.
Post by vwJim » Fri Mar 30, 2018 12:46 pm
The single circuit is not a power consideration, it's a risk of brake loss.
Dual circuit just gives you that chance of stopping if one circuit empties.
jon parker
Post by jon parker » Sat Mar 31, 2018 1:50 pm
Thanks Jim (You're a legend !), Expect an order soon !
