Canterbury Pitt door awning information required please...
Post by type21f » Tue Mar 17, 2015 12:56 pm
Wanted
Photo of Canterbury Pitt door awning popper position on the inside face of the cargo doors with measurements from fixed location, so I can install poppers on my cargo doors
orange
Re: Canterbury Pitt door awning information required please.
Post by orange » Fri Apr 17, 2015 4:08 pm
the popper position was always tight on my door awning and about 5mm difference on either side. so the measurements may be out or drilled off on installation.
Id probably get a ruff guide from these photos and the drill the popper to suite your awning.
Hope this helps
Post by type21f » Fri Apr 17, 2015 4:22 pm
Cheers!
I will trial mine and do just that..
Thanks very much for taking the time to photograph and measure and post!
Much appreciated!
I have the same colour way awning but wanted a green and white striped one...So I think I will have it copied and then drill the holes..
I will then be able to cheat and modify the design to fit on my Devon awning rail!
Cheers G
