Dormobile interior edge trim - where to get?
Re: Dormobile interior edge trim - where to get?
Well at the risk of boring you all I thought I would post pictures of my 65 Caravette Pop top opening trim Sorry but some may be twice....
I have a set of Dormobile trim to fit
from another Dormobile..
I have found not found a suitable alternative so far...
OG Dormobile strip that was fitted has a hockey stick profile and no one makes it.. like this...
The curved pieces have a rib removed and have then been heated and bent round a former..
I can fit some 4cm wide foam filled PVC finisher but it is square edged and plain...I may then use vinyl headlining material to cover it to match the headlining and some ivory P wing beading between the PVC finisher and headlining to act as a bump strip so if you stand up suddehly your flesh does not impact in a sharp edge....
Still looking though...
AFAIK Domobile no longer use this and have no finisher..
We could get some extruded! LOL
Will post a picture of my solution.
MarkFer
Post by MarkFer »
John TC wrote:A friend his having a new roof fitted to his bus on the 20th of this month,
I will get an answer for you if you haven't heard anything by then.
Excellent!
MarkFer
Post by MarkFer »
Graham - what are the dimensions of the og hockey stick section?
Mark.,
I will post some pictures..
LOL
With a rule...showing depths etc..
The long side pieces I have has some of the inner profile lip broken off at the very ends..
The curved pieces have this inner profile lip removed.
MarkFer
Post by MarkFer »
Thanks Graham. I hadn't realised until these photos that the x-section is more like an F-section really. And I did wonder what you meant on an earlier post when you said the curved lengths have the 2nd lip removed! Is the "socket" in the F-section used for anything? Is something sliped into the gap? Or would a true hockey shaped extrusion do the same job?
Mark.
My approach was to look for this as the best possibly available alternative...because this protects the sharp edge..
A flat section profile with a curved edge being an alternative with a piece of wing style p beading slipped in betweek might disguise the mismatch between a wavy edge and the hard straight edge of the profile..
The hockey stick or angled profile would achieve the same..
The original profile has the inner flange to achieve a slight stand off...again to protect the edge and hide the wavy edge..
Any news...I have none yet!
MarkFer
Post by MarkFer »
Nope, nothing to show for several hours searching Graham!
Once I get to that part of my interior build I'll probably machine up edge trim in oak.
Although I do wonder whether it is worth finding out how much it would cost to get something custom-extruded. If enough of us want a set it may be worth looking into. If I had a small section I'd look into it but I haven't anything.
I have a full set..! BUT..
Even if extruded.. the curved end pieces would be a challenge to bend.
I also thought of having a tool made and extruding a minimum length...
Maybe I will get a quote!
dottie the bus
Post by dottie the bus »
I need the rear piece if anybody has any? Or ideas for alternatives.
BBBBBrrrrrrrrrmmmmmmmmmm!!!!!!!!!!!!
Rev Heads!!!!!!!!
http://i48.photobucket.com/albums/f240/ ... G_0524.jpg
Large Gentlux? You do not have!
Oh no! Bullsh*t Warning. It is Emiliano Costellano again.. I thought you had died of Aids? Or was your sob story that your dad was dying of Aids?
Have I been scammed again.. Hi to you Hojoo... or is it Hobo? Trying to get your own back?
Delete his posts he is posting phishing links..
