Devon Carpets ?
Fuch77
Devon Carpets ?
Post by Fuch77 »
Has anyone got devon carpet under there rear draws?
I would very much like to see a photo if anyone can help as i once had carpet there that i would like to replace .
The norm seems to be hardboard with very few vans carpeted.
Can anyone shed any light please?
Re: Devon Carpets ?
My unrestored 65 Caravette has the full VW supplied hardboard cover shaped to fit screwed down with 10 screws n alloy cup washers..8 long n 2 shortened.
The short ones go either side of the latch plate on the over engine panel.
I could not understsnd why but whereas the other ones along the front screw into the void of the strengthening box section ..those two go through the panel and WOULD pierce you rear light loom.
Neither of mine have any carpet..
I have however cut some 19mm closed cell foam to fit onto the top of the 64 Caravette hardboard under the drawers for sound insulation.
But you have a WT Spaceway?
I can see the logic of having carpet to sit the spare wheel on top of to stop drumming.
I do NOT know if anyone else had carpet in that type of cupboard..
It may have been a PO addition...
Who has a Spaceway with carpet...?
Fuch77
Re: Devon Carpets ?
Post by Fuch77 »
Mine is a caravette G. it is possible it is a deluxe spec...?
Re: Devon Carpets ?
yes but with a unit to take spare wheel?
I see drop down flap?
Fuch77
Re: Devon Carpets ?
Post by Fuch77 »
spare is in the front G
Re: Devon Carpets ?
Ah...yes as a Caravette with division..
So maybe Carpet was for sound damping
Fuch77
Re: Devon Carpets ?
Post by Fuch77 »
I think so...do you know of anyone who has this we can take a look at?
