Gas pipe diameter on Dudley Cooker?
Byron Bamboo
Post by Byron Bamboo » Wed Oct 04, 2017 5:16 pm
I have a Dudley cooker and the gas inlet has been snapped off.
Anyone know what diameter the pipe inlet was, looks like 5mm but difficult to tell
The Gaffa Tape Tour 2007
'58 RHD PGSG Microbus
Re: Gas pipe diameter on Dudley Cooker?
Post by type21f » Sat Oct 07, 2017 8:44 am
Byron Bamboo wrote:I have a Dudley cooker and the gas inlet has been snapped off.
I AM NOT A GAS FITTER I AM A DEVON NERD and A QUALIFIED ENGINEER (METALLURGIST)
...lol
So nomenclature rules..
When people refer to pipe it is ID. When people refer to tube it is OD.
Before you read any further look at these pictures taken from items in my Dudley Cooker Hospital.
They determine the answer to your question...
Both have a fitting outlet.
This shows an outlet with a length of copper tube/pipe soldered onto a female fitting.
OD 9.25mm
This shows a female compression fitting with a piece of pipe coming out which MUST have an olive sealing it inside.
OD 8.85mm
Byron Bamboo
Post by Byron Bamboo » Sat Oct 07, 2017 8:53 am
I managed to get the small piece of pipe left out. It was 6mm OD.
It will have an olive sealing ring on it when it goes back on
Post by type21f » Sat Oct 07, 2017 9:06 am
Byron Bamboo wrote:I managed to get the small piece of pipe left out. It was 6mm OD.
Does the fitting look to have a compression seat to take an olive?
You can buy the females and olives.
EBay Toolstation Screwfix Wickes..
If the fitting does not look to have a seat the male MAY be tapered and like the first picture..to take s soldered fitting.
If fitting compression futtings always remember not to sit the cut end all the way in.. back it off a little.. the olive grips the pipe as you tighten so you need some closing gap. Measurements added above.
Byron Bamboo
Post by Byron Bamboo » Sat Oct 07, 2017 9:07 am
It's one for an olive, i pulled an olive off when I dismantled it
