Door unit and cooker identification....
Re: Door unit and cooker identification....
Post by type21f » Tue Oct 17, 2017 8:16 pm
russbmx wrote:Ended up making the stopped pivot hinges.
They haven’t been coated yet as I’m not sure what route to take. Gold zinc or silver? Was tempted by black but they won’t look very original then 8O
Here’s a photo of one
joke with Boyden..
sorry!
I know vwdave was looking for complete slider catches and I was asking about the bases..
the slide part is possible to machine the easily.. then a suitable knob. The base is cast with an attached spring..
Sent from my SM-G930F using Tapatalk
russbmx
Post by russbmx » Tue Oct 17, 2017 8:27 pm
joke with Boyden..
sorry!
Okay no worries lol.
I was tempted remove the complete sliding bolt and catch from mine but I don’t really want to that.
I didn’t really want to remove the hinges either :lol:
Post by type21f » Tue Oct 17, 2017 8:47 pm
On mine the hinges screwed on, maybe stripped before.
Looked at pictures of vwdave item..rivetted.
The slider was rivetted.. The rivet is a tube rivet with corrugations on the outside for wood!
I attempted to remove and made a real pig of it drilled the alloy rivet body but eventually that spun and then when pulling it out ended up with a real BIG HOLE..
DISASTER..
Was patched and unseen but learnt a lot!
russbmx
Post by russbmx » Tue Oct 17, 2017 9:01 pm
Ah, the hinges are (were) all riveted on this unit.
They won’t be now tho.
I definitely won’t be touching the slider.
I have another question :wink:
What is the correct name for the Formica on the inside of this unit? And do you know if it’s still available?
Cheers for your help
Post by type21f » Wed Oct 18, 2017 4:32 am
Grey muslin..I believe..
I know that it WAS still available but not easily found a few years ago. I was offerred a full sheet.
Was used from 1963.
Before that Brown muslin. I wanted Brown muslin for my 62. vwdave found some large pieces for me..
Never found a code
I know vwdave found some from a local contact... ask him if he has some spare.
Kevin Jackson sourced some but found it very hard to find and was looking at an alternative.
