Identifaction please ? unkown parts
Fuch77
Re: Identifaction please ? unkown parts
Post by Fuch77 »
ok im following all of that.
Does anyone know the answer to the question above about the double 025 and Swedish spec code please ?
There is one code which I believe covers all those options..
Do you have front seat belt mounts?
Think I saw them on B pillars
Do you have M24 mounts in corners of seat tubs?
M24 threaded fitting with 7/16ths UNF fittings..in the centre
Fuch77
Post by Fuch77 »
yes it does have them...so that means forget the US spec ?
what about the Swedish code?
Not sure about the 21 blunts...what do i look for?
Post by clymoj »
type21f wrote:
clymoj wrote:A spaceway had a different rear layout so the easicool shelf would have mated up to it differently:
Download and repost the picture...?
Photof***It
Not showing?
This better for you? Hopefully showing the photo better now.
This is actually a photo I think from Brian BJ1's Spaceway which he converted to LHD, however it shows the Spaceway rear seat and wardrobe in their normal RHD orientation.
Nice picture of the rear cupboard shows that is was wheel arch width and that the rear seat back was fitted up to a full height cupboard. Also shows the table alloy strip well and short alloy lower strip.
Fuch77
Post by Fuch77 »
SO to wrap this thread up i have a caravette spaceway BH model ?
Post by clymoj »
You have a Devon Caravette (bulkhead) model based on a deluxe microbus.
Someone has then swapped in half a Spaceway interior.
Hope that helps :)
Fuch77
Post by Fuch77 »
it does and i am very grateful to you all that have commented on this post. I feel I know the van better than ever now.
no one did really answer that 025 and Swedish code mystery though.
M codes are an Imprecise Science..
the codes appear on buses which are diverse..
The list on the samba.com has been expanded by Everett as knowledge grows..
Some appear to be easy to group.
The catalogue of what codes mean does exist but the plates MAY not be 100% accurate .. so the code may apply for one feature from an over arching spec..
So on the 025 spec.. remember seat belts were an option.. but I have seen that spec on a Swedish bus and all I could note was SEATBELTS..!
