3 devon Awning rails ? Advice please
Fuch77
Re: 3 devon Awning rails ? Advice please
Post by Fuch77 »
And are yo saying powder coat is best option for bringing them back up to nice standards ?
Post by clymoj »
That profile is the same as my 62 roof rail - the curved IC shaped one rather than the square [ shaped one Graham has.
It sounds like you have two roof rails so either one each side or you've acquired a spare at some point?
Post by clymoj »
Fuch77 wrote:And are yo saying powder coat is best option for bringing them back up to nice standards ?
There is some discussion amongst us nerds about whether they should be painted or left as bare aluminium. It is more likely to be the latter but may have varied by bus.
I think Graham polished his; I have had mine painted, so you take your pick I suppose.
Fuch77
Post by Fuch77 »
Paint would seem the easy option ....can anyone say how long the polished up lasts before retuning to the cracked ice look it has now?
Fuch77
Post by Fuch77 »
Also is there any way of knowing what type of awning it came with ?
Hack
Post by Hack »
just been down to check my 1980 lunar delta "meth lab" cavavan.
found this hanging off the bottom. two lengths 70" and 60"
UK 1967 Devon Caravette Spaceway
Ah...
Inspector Clouseau here..
clymoj..
Your bus was a Devonette...so did not have an awning or rail in the price list...
But the Buyer could have one and rail fitted as an optionsl extra.
Or it could be one was fitted later an an addition.
My 65 Caravette had a Devon Tent so had an extra long rail on the roof, with poppers on front bumper, around both front and rear wheel arches for the awning skirt.
I have replicated the poppers on my 64 Caravette.
pictures..
Fuch77
Post by Fuch77 »
Fascinating photos of the rails and skirts...My van once had the poppers and i had always wondered what they were for
Now i have seen it so very grateful.
not sure mine had that many as i remember.
you say you replicated them type21f ? is there a Devon type popper ? and are they the same as the ones used in the rear roll up curtain ?
They were the same as fitted by Devon
The OG ones shown on my 65 were slotted...
Unable to find slotted ewuivslents so have used posidrive ones but in now in stainless Steel. They were
blagged from the Jacuzzi maker neighbour to Dave..
These are also sold as Tonneau cover poppers...by...
Basically two sorts Male with screws
Female with caps as fitted on curtains n skirts.
Jacuzzi makers also stock them..
Can find on eBay too.
Flat sided 64/ 65 upper awning rail..
oeeer more rail porn..
I have now acquired s similar early flat sided 59" cill rail for my next project.
Going to try to strip paint off with plastic scourer tonight..
Will post pictures.
Have seen plastic putty knife used.
Want to abrade the paint off but not scratch the alloy..
Will try eith white spirit..
Maybe not paint stripper.. my skin is still sufferring from last attempts..
Dave said he used a plastic file as used on lead loading..on the 64
Will post pictures before n after
Hsve also aquired from the same source a long 82" rail but this has four big cross drilled holes and extra rivet holes.. it is bent at cross drill points and has extra rivet holes..
I think somone butcheted it to fit to a shed!
Will remove old rivet stubs.. clean strip and then attempt to straighten
Then decide if going to chop into two.. into transverse hammock rails.
I "borrowed" the one off the 65 to fit to the 64..
Seems sacriledge!
So will only cut when I cannot find a better one
So. I searched on the web about removing paint off ally and for overspray on alloy wheels advice was to use a plastic scourer or putty knife.. I tried but to no avail..
I thought my bottom rail was painted with red lead brushed on paint but on closer examination realised it was primed and top coated with SWR...
I then tried my wallpaper scraper to scrape the paint.
It worked..so I will continue bit by bit till all the paint is removed Then the rail can be polished.
The bottom rail is also slightly bent..
but can be straightened..ImageImage
