1965 MY cooker
1965 MY cooker
Post by type21f » Tue May 16, 2017 6:57 pm
Well I have had a bad dose of conscience...
The "Keep it Stock" man may have a cooker too early supplied with his bus.. not too sure..
WTB a 1965 MY Dudley cooker for Peebles to replace my 6 months too early 1964 MY Dudley cooker..... so just testing to see if anyone has one for sale..
I do not want to swap I want to buy..
I have some limited spares to rebuild if needed but I do not have the carry frame n shield..
Bathtub57
Re: 1965 MY cooker
Post by Bathtub57 » Wed May 17, 2017 1:52 pm
I don't have what you need but curious as to how you establish the MY of a Dudley? I have always been curious as to whether my 66 MY van has the correct Dudley?
1966 Devon Caravette
My Vans Thread http://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=51495
Mark Paine
Re: 1965 MY cooker
Post by type21f » Wed May 17, 2017 2:04 pm
I posted copies of the brochures at the top of the Devon thread and there are model pictures showing the model variants with semi distinct pictures.
Perhaps I should write a whole thread of what I believe I will extend this with micro images..
I will improve this entry..
LOL
Bathtub57
Re: 1965 MY cooker
Post by Bathtub57 » Thu May 18, 2017 4:26 pm
Defoe need a padding out of this topic!
I have three an Argyl and two versions of the Dudley, one which may be a 65 as it is a lift out version with the shield and the one in my bus for which I am looking for a shield the more modern looking Dudley. I was going to rob the shield from the earlier one but debating whether to fit the earlier one wholemeal into my bus.
I'll get pics when I am back in the country. If it is a 65 I have and I can find a shield for mine I might be able to help you out.
If you have pics of a 65 and a 66 version I may be able to identify remotely. This is what I have - is it correct for my '66 and where do I find a shield? (rhetorical question)
Mark Paine
Re: 1965 MY cooker
Post by type21f » Fri May 19, 2017 2:58 pm
We have been here before...
Lol
viewtopic.php?f=46&t=101984&start=15
I will post pictures and dates as I find them to this post for the Devon nerds and then cut and paste all onto a new reference thread and seek a sticky status.
So comment away and add for discussion.
**1958 1959 1960
**1961 hourglass cooker white with black burners. Single round holes
** 1962 fold up elusive black topped Dudley green cooker with grill on Caravette with low level fold over shield.
Note hole in centre of shroud back/ lid related to male catch plunger on lid....
** 1962 Devonette. Door mounted cooker. October 1961 on front cargo door. 1962 rear cargo door
** 1963 Devonette low shield cooker for use inside mounted on the front of the tall cupboard
** Early 1963 continuation of Black topped Dudley with low side shields Devon leg plates on the bottom and gimbels on the sides (as used on a boat)
and grill pan - probably non standard..
Others have an alloy pan
** 1963 Caravette, solid case black topped with fold over low shield with tube legs fitting into tube sockets inside the grill area
black top.. no lift out handles on the sides...some angled brackets on the sides...Maybe an owner addition on both sides but have seen a Devon sliding table catch screwed to a cooker unit and realised this was how the cooker was secured on an open surface to stop it sliding.
** 1964 Devonette model clamped onto the top of a surface
** Late 1964 with tube legs and a tall shield and plate rack for standing outside as per Doogle's grand dads picture
** 1965 MY with frame and handles to lift out of cupboard with plate rack and tall shield. No leg plates.. designed just to sit on table..
** 1966 several variants depending on model
New World Argyl cooker etc
** 1966 Caravette Standard (Division) Dudley cooker
With carrying Frame and tall enclosed shroud for use outside, missing the plate rack at the top.
With Devon style leg plates on the base.
This one has the Dudley logo
** 1966 Caravette Spaceway
** 1966 Torvette standard
** 1966 Devon Torvette Spaceway cooker on a kombi usually sat in a case mounted to the back of RHD passenger seat.
Same cooker as that fitted to earlier 1962 Devon Devonette
WiP
miles
Re: 1965 MY cooker
Post by miles » Fri May 19, 2017 5:03 pm
You Devon lot, and your cookers. You should improvise.
Suggest you go down the patina cooker route :)
I think it will give the van a lived in look :D
Canterbury Pitt Interior Instructions are here:
http://chocksaway.com/pitt/index.html
Re: RE: Re: 1965 MY cooker
Post by type21f » Fri May 19, 2017 5:54 pm
miles wrote:You Devon lot, and your cookers. You should improvise.
err pot calling kettle black... err
Recognise this miles..
Who is ANAL?
1957 Pitt cooker?
miles
Post by miles » Sat May 20, 2017 8:20 am
Who is ANAL?
1957 Pitt cooker?
Misrepresentation - that cooker was never fitted :)
Re: RE: Re: RE: Re: 1965 MY cooker
Post by type21f » Sat May 20, 2017 8:25 am
Who is ANAL?
1957 Pitt cooker?
Is that you never fitted it... or it was not fitted to Pitt?
So did you or did you not search for a year correct cooker to fit?
Binary answer only allowed..
Yes or No?
miles
Re: 1965 MY cooker
Post by miles » Sat May 20, 2017 8:31 am
Errrr Yes :)
Post by type21f » Sat May 20, 2017 8:37 am
miles wrote:Errrr Yes :)
Honesty is always the best policy..
Expected to see you at SH..
miles
Re: 1965 MY cooker
Post by miles » Sat May 20, 2017 8:40 am
OK, the cat is out of the bag :) OG cooker :)
Enders 9065D Cooker and Sirram tea set :) Cooker needs a fettle, but has boiled a single cup of tea :)
miles
Re: 1965 MY cooker
Post by miles » Sat May 20, 2017 8:45 am
There is another cooker in the bus. A small gas two burner :)
Post by type21f » Sat May 20, 2017 8:53 am
miles wrote:There is another cooker in the bus. A small gas two burner :)
Re: 1965 MY cooker
Post by type21f » Sat May 20, 2017 8:54 am
An Anorak always knows an Anorak when he meets one..
