kühlspeed Ram Air Scoops from £96+p&p
malum
Re: kühlspeed Ram Air Scoops from £60+p&p
Post by malum »
Ordered a pair yesterday and they arrived today. Good work
Not fitted yet as the bus is in bits and I have to paint them.
I am running a Subaru engine and the engine bay gets very hot after a run at speed so hopefully these will sort that out. I was going to fit some engine bay fans but this seems an easier solution.
dsbus
Post by dsbus »
new batch just in - keep your cool this summer!
stu(pid)
Post by stu(pid) »
What's available for a 66 at the moment? The website only shows alloy/stanless for £90, is that correct?
david5367
Post by david5367 »
Hi mate,have you got a set for a 65 if so how much,PayPal details please.
Cheers David
dsbus
Post by dsbus »
stu(pid) wrote:What's available for a 66 at the moment? The website only shows alloy/stanless for £90, is that correct?
Yes, the latest scoops are a bit more expensive taking into account longer to TIG, prepare and increased costs....
Bump for a flag cracking day 8)
dsbus
Post by dsbus »
david5367 wrote:Hi mate,have you got a set for a 65 if so how much,PayPal details please.
Cheers David
here... http://www.kuhl-tek.co.uk/ourshop/prod_ ... ckets.html
stu(pid)
Post by stu(pid) »
Set ordered. Thanks.
malum
Post by malum »
I decided not to paint mine in the end. Figured they aren't original so I didn't want them to look like they were part of the bus
I polished them up a bit instead
OP
Post by OP »
How much posted for a 55 non barndoor mate?
andydlc
Post by andydlc »
Two questions - have people found they mark the paint or dent the vents? Do people use a bit of rubber stop body rub?
Andrew
malum
Post by malum »
They come with rubber strips to go between the scoop and the body. You can see them on my photo above.
You have to be a little careful when fitting not to mark the paint when screwing them on as the screws pass through the vents and if you are sloppy you could scratch the paint, but it's not difficult. I don't think you could dent the vents unless you over tightened the screws
You need two people to fit them, one to hold the bracket on the inside and one to screw them on from the outside
dsbus
Post by dsbus »
OP wrote:How much posted for a 55 non barndoor mate?
available here: http://www.kuhl-tek.co.uk/ourshop/prod_ ... ckets.html
malum
Post by malum »
Well I had a chance to give them a good test. A 500 mile round trip to Carfest North.
These scoops knocked 10 degrees C off my engine temp. This is bowling down the motorway at 75-80mph.
Most of you will not be running water-cooled set-ups but that will give you some idea of how much air they are getting in there.
dsbus
Post by dsbus »
Soon be summer 8)
lids_2001
Post by lids_2001 »
Are all models available?
Tourist exchange with optional extra of a rubber mat!
