Steering Box Lift Kit £48
dsbus
Re: steering box lift kit. from £57.50
Post by dsbus » Thu Dec 09, 2010 12:00 pm
LHD kits in stock :D
monkey
Post by monkey » Fri Jan 28, 2011 10:03 am
Hi DS Bus. I'd like to sort out one of these kits for a rhd bus. It's not urgent as they wont start the resto until march when it will be on a body roller. It will be the ideal time to take out the steering box and when they're repairing the underneath they might as well install one of these as well.
Please can you explain what I need to do with regards to getting the machining work done (what you need me to supply etc) I might as well get the lot done by you so I can be sure it's done properly.
I'm a bit clueless on what is done when the box is lifted and the thread is so long I got lost after page 3. So you'll need to give me full instructions on what you need!
Matt
sbs#26 UK Chapter
Post by vwJim » Fri Jan 28, 2011 12:42 pm
Question for everyone that has theirs lifted....
How do you top up your steering box oil level?
Do you leave it and forget it?
Do you fill with liquid grease?
Do you drop the steering box down once a year?
Do you cut an access hole in the chassis rail to access the filling plug?
dsbus
Post by dsbus » Sat Mar 05, 2011 10:27 am
I use Penrite Steering Box Lube:
dsbus
Post by dsbus » Wed Apr 13, 2011 12:46 pm
Back in stock :D
dsbus
Re: steering box lift kit. from £62.50
Post by dsbus » Tue May 17, 2011 6:40 pm
:bounce:
Matt Black.
Post by Matt Black. » Tue May 17, 2011 8:37 pm
i'll be after one of these very soon!... i have skipped through this thread as i dont have the time to read it all the way through tonight.... but noticed talk of a "Box Balm" kit..??? i have an inch or so of play in my steering box... replaced pitman arm etc... i think the play is in splined pin that exits the steering box and is atached to the steering arm... it seems to have some up and down movement in it... a little like it needs bushing
dsbus
Post by dsbus » Tue May 17, 2011 8:51 pm
Cut to the chase... All you need to know itn two handy photobucket slideshows :D
dsbus wrote: fitting instructions for the Lift Kit:
http://s72.photobucket.com/albums/i195/ ... =slideshow
Other service, column shortening and rebuilding steering box:
dsbus
Post by dsbus » Sat Jul 16, 2011 2:25 pm
3 sets off to Holland this weekend :D
Material now in to make 6 LHD and 5 RHD kits
SAMBA VAN MAN
Post by SAMBA VAN MAN » Thu Jul 21, 2011 5:45 pm
Mike's kit's are great free bump :cheers: :cheers:
Never stand on the toes of someone today, Who's A$$ you could be kissin tomorrow.
Paul
Stevo
Post by Stevo » Mon Aug 08, 2011 12:56 pm
Hi,
Have you got any more kits available - i've got a LHD 57.
Stevo
babyvan
Post by babyvan » Sun Sep 04, 2011 7:28 pm
Ive been forwarded this link, can you please let me know what the current prices would be for all the works listed.
Manythanks
Jamie
:D :D :D :D
Post by vwJim » Sun Sep 04, 2011 7:40 pm
dsbus wrote:3 sets off to Holland this weekend :D
Probably need a RHD kit after BB. Actually might be able to collect at BB if you're there this year?
dsbus
Post by dsbus » Fri Sep 16, 2011 5:01 pm
Jim, 1 x RHD Kit welded up, I'll get it over to Billy to take down to BB. Cheers, Mike
NathanAndDeb
Post by NathanAndDeb » Sat Sep 17, 2011 7:17 am
SAMBA VAN MAN wrote:Mike's kit's are great free bump :cheers: :cheers:
WHS ^. Fitted mine last weekend, cut out and welded in chassis section and re-fitted box in a day.
Thanks for a great kit Mike.
Cheers Nathan
