New build turnkey 1600
scottish splitty
Post by scottish splitty » Tue Aug 27, 2019 9:08 pm
Fresh built 1600 turnkey engine,this engine is ready to ship just needs model specific tinware etc fitted
SPEC
USED -AS 41 VW ENGINE CASE
USED -REGROUND VW CRANKSHAFT
USED-VW CON RODS
USED-VW CAMSHAFT
NEW -STEEL BACKED BEARINGS
NEW-GERMAN CAMSHAFT LIFTRRS
NEW-SHADEK H.D OIL PUMP
NEW-OIL PUMP COVER
NEW-MAHLE 1600 BARREL/ PISTONS
NEW-PUSHROD TUBES
NEW-EMPI CYLINDER HEADS
NEW-STAINLESSS VALVES
NEW-EXHAUST STUDS
NEW-VALVE SPRINGS/RETAINERS
USED-VW ROCKERS/TAPPETS
NEW-ROCKER COVERS AND CLIPS
NEW-FLYWHEEL
NEW-SCAT 30 HP TIN WARE KIT PAINTED HIGH GLOSS BLACK
NEW-STAINLESS STEEL FASTENERS
NEW-COOLING FAN
NEW-ALTERNATOR
NEW-ALTERNATOR PULLEY
USED-VW CRANKSHAFT PULLEY
USED-VW INLET MANIFOLD
NEW-AIRCOOLED REPRO SOLEX 34 PICT CARB
NEW-FUEL PUMP
NEW-FUEL HOSES
NEW-8MM SILICONE H.T LEADS
NEW-VACUUM ADVANCE DISTRIBUTOR
NEW-IGNITION COIL
NEW-J TUBES
£2700
ENGINE SOLD OUTRIGHT WITH FULL 1 YEARS WARRANTY
ENGINE AWAITING TINWARE OPTIONS
AIRCOOLED ENGINES (SCOTLAND)
UNIT 5 BLOCK 1
ALLOA INDUSTRIAL ESTATE
WARD STREET
ALLOA
FK10 1ET
CREATING PLATINA SINCE 2010
scottish splitty
Re: New build turnkey 1600
Post by scottish splitty » Thu Sep 19, 2019 8:48 pm
sold
,another 1600 long block now in stock...
scottish splitty
Post by scottish splitty » Wed Oct 16, 2019 5:21 pm
Sold ...
