Type 4 engine Massive build. SOLD
VRsixth
Post by VRsixth » Fri Aug 24, 2018 1:39 pm
Here it comes for sale. Big project fuel injected Type 4 engine.
Thousands of work hours spend , same as thousands of $$
Spec:
Type4 engine completely refurbished equipped with upright type 1 cooling.
All parts replaced new / refurbished.
Huge spec:
71x94 2.0 liter type 4
Flat top Kolbenschmidt pistons and cylinders set.
9: 1 compression
Lightened, balanced and polished connecting rods - 728g each (stock is 860grams) Rods are balanced with pistons and pins up to 0.1 grams. Rods are lightened and shape optimized by FEM analyzes.
Crankshaft balanced, new bearings.
Lightened flywheel (1,2kg)
Ported cylinder heads, new inlet and exhaust cross section. Inlet port 38mm (stock 34mm) exhaust port 28x38mm (stock 24x34mm)
All work done by professionals tested on flow bench. What we found it much better than 914 heads!
New valves came with stock, new guides and seals.
300 degree Ahnendorp camshaft.
SCAT "lube a lobe" solid lifters.
CroMo pushrods, HD springs
Custom design intake manifold 38mm ports, 500cc plenum optimized for flat torque.
Very long inlet runners designed to give more than 200Nm of torque as tested. No need to go for 2.4 liters
62mm throttle body.
Siemens Digifant fuel injection, with BOSCH 205cc fuel injectors, aluminum rails
Refurbished 55A Bosch generator
All bearings new Kolbenschmidt, seals by Victor Reinz.
External oil cooler adapter.
Custom made type1 upright cooling with fully working thermostatic valve.
Really hard to evaluate this project, think about 6500 ono
VRsixth
Re: Type 4 engine Massive build.
Post by VRsixth » Mon Aug 27, 2018 3:48 pm
On ebay if like to bid:
https://www.ebay.de/itm/173481793123
dazza1234
Post by dazza1234 » Sun Jan 13, 2019 3:59 pm
is this still for sale??
vwbuzzers
Post by vwbuzzers » Mon Jan 14, 2019 10:13 am
Looks like it sold on eBay ?
Buzzers
tyler
Post by tyler » Tue Jan 15, 2019 7:40 pm
Dazza, pm send
VRsixth
Post by VRsixth » Tue Jan 29, 2019 4:49 pm
Sorry for late answer , been busy as hell.
Yes it's sold
I'm working on new supercharged project.
VWFREAKSTER
Post by VWFREAKSTER » Sat Feb 02, 2019 7:19 pm
Very nice.
Jaisimpson
Post by Jaisimpson » Tue Feb 05, 2019 11:22 am
That looked amazing
1968 deluxe bay Montana red
1959 beetle ceramic green
