Selling a type 3 003 autobox. Ideal for a type 4 engine and then into a split.
It is the autobox complete with final drive and torque convertor.
No driveshafts or flexiplate.
In good order.
£1000 ono
003 autobox
Re: 003 autobox
So no Flexiplate!!
- SSVC Member
Re: 003 autobox
Interested in your auto gearbox,could you confirm you are selling the automatic gearbox and torque converter only for £1000.
Are the flexi plates and driveshafts available at extra cost (if so how much)or are they readily available ?
I'm assuming this gearbox been overhauled if so was it all new internals,clutches,seals etc,also would there be a warranty with this gearbox.
Thanks in advance
Paul
Thanks in advance
Paul
Re: 003 autobox
Hi Paul.scottish splitty wrote: ↑Sat Aug 12, 2017 8:14 pm Hi
Thanks in advance
Paul
You are correct. Re the driveshafts they are standard driveshafts from a type 3 or type 2 from a 3 rib and up gearbox. Re the flexiplate you will have to search for either new or used. Im not sure if a type 25 could be altered or not. You will need to research. The gearbox has not been overhauled there is no warranty. I can get the box overhauled with a receipt and warranty circa £300. I myself recently bought a 6 rib manual box for £800 and spent another £300 on a rebuild myself.
I hope ive answered ll your questions.
Regards
Darren
Re: 003 autobox
The drive shafts are not, they are specific to a Auto Box. they are offset so different lengths that is why you had spacers
Re: 003 autobox
Ahhh yes though the spacers can be made to suit your individual application. I very much doubt the driveshafts are offset !!! They may be different lengths. Do you know where there is a set available as they would be very handy.
- SSVC Member
Re: 003 autobox
I have type 3 driveshafts and endplates but from a manual gearbox car IRS.
