sekurit and sigla glass 1952-67 brand new
new glass with correct logos for Barndoor buses and later buses these have been copied from original pieces and then have the logo put on to suit! This is all 5mm toughened. I have at present front windscreen cab door glass pop out and fixed side the only rear glass I have is for a deluxe but will be having the others made. I have had a set fitted in a 57 and tried them in a 54. Prices will range from £35-70 per piece. I now have barndoor safari glass and the piano hinge glass along with standard rear window and deluxe. Also doing sigla logo and have the none hole slider but this will be toughened not laminated.
Re: Barndoor and later glass
I am very interested in a pair of early windscreens, Can u give us an idea of where you are based, also price and postage costs. I may come to slough to pick them up. Ta.
- SSVC Member
Hi have you got '56 glass the difference being the dot after the T and dot under the E
http://www.dropgates.com/y2y/logo56leftside.jpg
just ordered the tooling for the 56 logo so should be with me early part of next week will post a picture when it arrives
im after some barndoor glass , i'll be in touch , thanks garry
..............................useless..................................
Just had another batch of glass in so I can do sets for barndoor and later buses
- SSVC Member
- Contact:
Re: sekurit glass barndoor and later
After 8 pop outs for a 61 if you have?
Griff
63 sc daily driver
62 ratty 11 window
60 deluxe bus
55 Snail camper (project)
63 sc daily driver
62 ratty 11 window
60 deluxe bus
Re: sekurit glass barndoor and later new batch just arrived
New batch just arrived!
Interested in some front screens for a 57 how much?
SBS#67
RULE#100
57 kombi
NEIL
RULE#100
57 kombi
NEIL
Do you do any for safaris?
I can do safaris yes depending on which ones you have
- SSVC Member
How much for complete set of glass for a 56 please
Time to get the welder out again
new later style not quite 100% as this is etched rather than printed !
Do you have front glass for 58 split with correct logo. Also side pop out glass. If so can you forward a price
