Polished bumper trim £330
chilliman
Re: Polished bumper trim £330
Post by chilliman »
Thanks mate got it!
1963 23 Window Samba - 2110cc (In Restoration)
ALHINSON
Post by ALHINSON »
I have the same issue with mine, specifically with the rears,I think the profile is for the earlier pressed 1950s bumpers as mine are out my a good inch or two and they certainly aren't easy to bend! Can anyone give me a solution please.
1963 11 Window Standard, Turkis Green & White, French Import
1967 13 Window Deluxe, Sea Blue & Cumulus White, Arizona Import
chilliman
Post by chilliman »
The rears are the problem my restorer thinks they need to be annealed?!
ALHINSON
Post by ALHINSON »
Annealing aluminium isn't that simple though, it is a fine line between heating and melting!
Are deluxe trims designed for earlier pressed bumpers a different profile to later slash cut rear bumper trims? I think that is the issue. The trims are designed for earlier bumpers, perhaps.
ppp
Post by ppp »
no, do not do the annealing... just a little tap is fine. The aluminum is soft enough to be bent by tapping.
gunlau
Post by gunlau »
Is this still available? I have slash cut bumpers on my brazil bus.
Witch set do i need? What is the cost to send it to Belgium?
ppp
Post by ppp »
pm sent
paul8744
Post by paul8744 »
Hi There, How do i order these bumper trims? I have a South African Splitty that was built in Brazil with the towel rail style bumpers that slash up and backwards, do you know which trims i would need, i have a photo but for some reason i cant post them here, maybe you can send me an email address where i could send you a picture just to be 100%?
Kind Regards
Paul
ppp
Post by ppp »
Hi Paul, you can send pictures of your bus to my email.
napat@thaivwclub.com
PAT
jackricha
Post by jackricha »
Hi Pat,
Just a little helper try to make your 1's not look like 7's as customs charged me £180. Payable upfront, in the process of trying to get a refund.
ppp
Post by ppp »
Sorry to hear that but I really wrote it down "1" for sure.
Hope you can have your money back.
jackricha
Post by jackricha »
Hi Pat, they should, they have the PayPal information etc.
Just for everyone else thinking of getting some trim. Pat has been brilliant from start to finish and the product looks great also.
Thanks Pat
ppp
Post by ppp »
:-) thank you
Ollic
Post by Ollic »
Hi Pat,
how much would#2 Euro spec bumper trim with point end in both front and rear
be to Germany?
Cheers!
Oliver
ppp
Post by ppp »
Hi Oliver,
Price is the same to UK £330
PAT
