1914cc type 1 engine
rikki james
Post by rikki james » Thu Feb 13, 2020 6:07 pm
Brand new 1914cc type 1 is case, counterweight crank, forged rods and flywheel, 1700lb clutch pressure plate, 94mm pistons, Mofoco 042 heads 40 x 35.5 valves, dual springs, cut to length push rods, bolt up rocker shafts, twin 40 carbs, Arnedorp air box, CSP swivel linkage, new tinwear, tapped for full flow oil, heavy duty oil pump, new coil and 009 dizzy and leads, Vintage Speed exhaust etc etc... 6k
Call me on: 07802 884583 :wink:
Rikki.
