Rolling Road Results
You're gonna like us :-)
Glyno
Post by Glyno »
Just had the call from the guys setting up the engine in my crew cab. Well chuffed.. Peak power of 146Bhp at the flywheel.
Should mean I have a decent bit of fun in it this year...
Great to get it sorted after all the hassle with it - sure it will all be worth it when the sun is shining :)
richierich37
Re: Rolling Road Results
Post by richierich37 »
8)
RICHIE C
SBS UK #37
P.B. 16.88 @ 77.1MPH
http://www.steeringboxscrapers.net/
orb
Post by orb »
Nice one, should run low 16's.
See you on the strip :wink:
Orb
Glyno
Post by Glyno »
Better take the cooler and roofrack off for that :)
Where'd you go?
Ollie
Post by Ollie »
8) 8) :bounce:
Lets have the spec then!
'it just bolts right up...'
Glyno
Post by Glyno »
Sorry for the late respone I missed the thread replies!
It was set up at Read Performance in New Milton http://www.readperformance.co.uk
Top guys - really looked after me and took the time to setup the engine properly. Fuel pump was unable to keep up with the carbs, carbs were a mile off etc etc.
It is now so driveable. Around town or on full throttle it is completely smooth.
Current engine spec is :-
AS41 case bore 90.5, clearance 82mm. D tap for full flow
82mm Crank
Scat H beam 5.5 length con rods
Scat C45 cam with 1.25:1 ratio rockers
Scat Pro Drag wedge port heads
Manton push rods with total seal rings
Full flow oil system with remote filter - cooler to be fitted this weekend
Twin Weber 44 IDF carbs with CSP crank swivel linkage
Full merged fat boy ss exhaust system
Kennedy stage 1 clutch
Petronix flame thrower coil, leads and electronic ignition
009 Dissy
Holley electric fuel pump.
Glyno wrote:It is now so driveable. Around town or on full throttle it is completely smooth.
That's the benefit of a good rolling road session, and piece of mind that there's no nasty lean moments when gunning it.
I'd be suprised if that stage 1 doesn't struggle to hold the power if you push it on the track. Nice sounding engine package though.
Glyno
Post by Glyno »
Yes totally agree. The guys at Read said it wouldn't have lasted very long as it was setup... Great to know it is now running spot on.
Also really looking forward to you doing the rack conversion as well Jim. Be nice to hold it in a straight line!!
