Sway-a-way type axles
You're gonna like us :-)
jerrythegerman
Post by jerrythegerman »
Anyone run these or the same as these?.
What sort of power/torque do the original Swing axles let go?.
I think mine would be the long ones.
"It's rust Jim, but not as we know it"
Re: Sway-a-way type axles
Are you SA'd?
I broke my OG axles on the Santa Pod start line, and blew the diff' out the side of the gearbox too.... That's when I had a lot less power than I do now, went for Race Axles. You'll see how much stronger they are just from the shear size of them.
You'll neen them if you ever put the power down of your new engine.....
jerrythegerman
Cheer's Jim, noted. Yes, S/A'd, got a Pro street box sorted, just the driveshafts now.
Don't suppose you stock them do you?
jerrythegerman
Have done in the past, but out in France at the moment, so none in. The prices do vary quite a bit, so hunt around.
