Bit the bullet!!
You're gonna like us :-)
jerrythegerman
Bit the bullet!!
Post by jerrythegerman »
Well after skullking around this end of the site I've gone and spent the money. :roll:
Just checking what I've bought will do the job!!???
Bought a 2110 from Vw speedshop, spec as follows:-
CB case,
82mm forged CB crank,
Mahle 90.5 stroker kit,
CB H beam rods,
13lb flywheel,
044 Magnums 40x35.5
Engle FK7 cam,
1.4 rockers,
Bigfoot followers,
Manton chromoloy pushrods,
Jaycee tubes,
Twin 40 DRLA's (already have those on the present engine)
Bosch 009 with electronic ignition (already had)
kennedy stage 2.
What's that going to put out?
What's a butty midmount and do I need one?
any guess's what time's i'd be looking at?
Do I need a welded fan?
All going in '64 11 window, SA'd (3.88 diff) and CSP disc's (thankfully!!)
"It's rust Jim, but not as we know it"
orb
Re: Bit the bullet!!
Post by orb »
Well done that man :D
That should build you a good, stout motor - should get you into BWA easily.
As to power it's hard to say but it should make 120bhp and good torque with the 40's - reckon you'll run a late 16/early 17 with that given what mine did with similar power (my old engine)
Nice thing is it'll be a good starting point that you could upgrade and make quicker if the bug bites hard :wink:
You've got scope to get more power outof it with head swaps, bigger carbs, lairy cam etc.
Keep us updated, be interested in what it makes
Orb
P.S. to get the best results budget for a rolling road set-up - worth every penny
jerrythegerman
Thanks Orb, that was the idea of that spec engine (plus some sound advice from Stef at MAC).
I'm a converted man on the rolling road, it has proven it's worth on plenty of my previous car's, definately worth the outlay even if it's just to provide more drivability.
Did you run any fancy supports or mounts? or is that for the next stage up the power ladder?
While you've got improved access, ie while the engine is out, fit one of Butty's mid mounts. Will help save your nose cone mount.
m1xmag
Post by m1xmag »
Thats going to build a stonking motor alright - should pull like a train 8)
'67 Sportsmobile
I'm not giving up yet.....
jerrythegerman
Yes thanks, after much sole searching (and scraping together of funds!!)
I've just ordered the gearbox to match. A Rancho Prostreet with a longer 1st, 4th and a chromoloy pinion nut. I've opted for the 3.88 final drive too, I know it may hurt the acceleration but I need it to cruise too (it is a family camper too!!).
On the strip, with longer gearing, will I just leave it in 3 rd for longer (changing to 4th will cost me time??)
Thank's Jim, I'll look up that mount and get one ordered.
Hopefully it should be all in and running this side of xmas, get some miles on it then the rollers. Just joined the SSVC so will look to hit the strip spring time next year, eventually get the time down (that may take a while!!) and hopefully apply for the BWA.
Is there specific dates when you need to qualify so that other members are there?
orb
Post by orb »
3.88 will be fine - should cruise at 3500rpm @ 70mph or thereabouts depending on tyre size and you won't need 4th on the strip (mine runs to over 90mph in 3rd!)
I'm not up on the specs of the Rancho boxes but I'd make sure it has 3rd and 4th gear welded as you'll be unwinding them with that sort of power in no time!
Sounds like it's all coming together nicely :wink:
Orb
jerrythegerman
Those mid mounts look like that they are for IRS box's only, Mine SA'd. What's the equivelent?
butty
Post by butty »
Mine fit straight axle and irs , they are the same , only creative ones are different , will be at ace and slough if want to have a look at them .....
Cheers vw jim .... :D
Follow http://www.facebook.com/ButtysBits for new items coming....
www.buttysbits.com
Safari seals , safari window sliders .......
Under floor throttle assemblies , Intermediate gearbox mounts split bus only ,
Wheel adapters , drum spacer kits , Steering wheel removal tools ......
Menace
Moderator
Post by Menace »
Sounds good 8) You know any probs with the box & its gotta be resolved stateside :!: If its not too late contact Paul @ Bears 0121 742 2200 & he will build to your needs, & only in Birmingham :wink:
_______________________________________
N.Y.E. HARDCORE CAMPING POSSE 2005-2011
1957 Kombi
maddison wrote:SSVC should be how it is, real club for real enthusiasts, with a real forum of usable , storable data...to keep for all time
jerrythegerman
Thanks Billy, but the order has already been placed. TBH I've only heard good things about those boxes.
Yes, its got welded 3rd and 4th.
The only week link I could think of now would be the drivesahft's (and the driver!!), but I doubt I'd be in the power area of breaking them.
vwbuzzers
Post by vwbuzzers »
So your the guy i think i was there when you phoned up, stef and paul are both good friends of mine. Where are you based?
jerrythegerman
Near warringon, cheshire.
vwbuzzers
Post by vwbuzzers »
update needed :wink: hope i don't have to follow you to any shows :lol:
jerrythegerman
Shhhh K!!!!, lets just say the spec has changed a little!! and I may need fresh pant's more often.
