VW suppliers selling poor qaulity fuel line, Petition
Re: VW suppliers selling poor qaulity fuel line, Petition
Anyone know if the insurers give a discount for having a fire suppression system fitted ? Maybe we need a petition to them ?
:D
HairyYeti
Post by HairyYeti »
I came across this a little while ago courtesy of my Rover V8 crowd :
http://www.v8register.net/a35/v8annidayreport1.htm
If you take the time to go through the downloads there is some very good research and insight into the effect E10 fuel may have on older cars.
Interesting they say only to stick with clearly established and marked-up brands ; avoid "unbranded" fuel hose.
Aerospace Design Engineer
Ebeneezer
Post by Ebeneezer »
I bought this R9 rated fuel line from Codan and it was significantly cheaper than anywhere else :-
http://www.flexiducting.co.uk/automotive_hoses_26.html
Wouldn't something like this be an ideal addition to the SSVC shop?
Paul
07968 483522
Evil Sid
Post by Evil Sid »
In addition to the Rover V8 stuff it's worth being aware that adjustable fuel pressure regulators are also susceptible to the same problems. I was speaking to someone yesterday who had this problem causing a leak under the adjuster
I guess that is an argument for running a fuel pump that doesn't require one as their internals are a completely sealed
1966 Microbus Deluxe
Evil Sid wrote:In addition to the Rover V8 stuff it's worth being aware that adjustable fuel pressure regulators are also susceptible to the same problems. I was speaking to someone yesterday who had this problem causing a leak under the adjuster
Yup I can vouch for that. I had a sytech regulator on mine and after a nice mellow drive home from Santa pod I started the bus up to pop out again and saw the trail of petrol I was leaving on the floor 8O Had a look and the diaphragm had split and the regulator was spraying fuel all over my nice hot engine. Had this happened whilst I was sat at 70mph on the motorway I probably wouldn't have noticed until it was too late.
I've since replace the sh!tty sytech one with a fuel king regulator and filter.
Shalom, Lee
Sisu
Post by Sisu »
Noted that the kits sold by Machine7 and alot of you are running with jubilee clips or screw metal clamps for the fuel lines.
New cars have spring clips rather than jubilee clips for the fuel lines as unlike jubilee clips they have a constant pressure regardless of temperature.
srfndoc
Post by srfndoc »
Have you guys look at the metric fuel line from Belmetric.com:
https://www.belmetric.com/rhm5-flennor- ... ath=14_662
It comes in 5mm size which is very close to OG and has held up well for me in the last year. Many others are using
it as well.
Le Counte de JAYFOR
Post by Le Counte de JAYFOR »
Chunksta wrote:I wasn't aware of the ethanol issue until we went to the Breeze.
Something needs doing quickly to save anyone else losing their pride and joy.
Andrew Read (readyboy61)
Nick Moss (Malum)
Richard Shackleton (8 8US)
Tom Bailey (tombailey77)
Menace (SSVC President)
Nigel Allister (nige1171)
Nick McLaren (mclarni)
Martin Salt (vw-mk1)
Trevor Bailey (Samba63)
Brian Thompson (bleedingmoody)
Steve Maddison (Maddison)
Jake Shuttleworth (Sooty)
Mark Fereday (markfer)
Simon Spencer (SpennysSplitty)
Lee Eversley (da Empster)
Jonny McCall (JonnyCJ)
Mark Parker (funkyfreakapotomus)
Grant Kennaird (Gruntilla)
Mark Boardman (splitscreendreammachine)
Colin Nicol (cocobus)
Al Kinmg (X-F1)
Simon Coldwell (Reggie)
Tony Moore (Chunksta)
Joseph Bakhsh (Le Counte)
