Calling all Khyam motordome owners!
DubDays
Post by DubDays »
Just attaching mine to the bus for the first time and a bit of confusion has occured. We've got the pole and clamp method and from what I can work out you can't attach the awning to the bus with the doors closed? Equally you can't close them once it's attached? Can anyone confirm this?
Martin.
Post by flatbeat »
You can only really clamp it on the ends as the middle clamps get in the way.
brianjbox
Post by brianjbox »
I don't know what the pole and clamp method is? my motordome attaches to the gutter with the figure of 8 strip stuff and you can open and close the doors ok :?
urbanvw
Post by urbanvw »
my bus has got a roof rack and its never easy, any suggestions?
23A
Post by 23A »
..urbanvw....just found a pm to you STILL in my outbox- do you ever check your pms? :roll: :wink: :D
..ps its about Sunpro fuel gauges & senders... :D 8)
Image Image
http://www.earlyvw.com
..now an agent for Butty's Bits ..
Choc
Post by Choc »
flatbeat wrote:You can only really clamp it on the ends as the middle clamps get in the way.
That's about right.
1 clamp at either end of the pole and 1 just before the doors start.
urbanvw
Post by urbanvw »
no!
brianjbox
Post by brianjbox »
urbanvw wrote:no!
I use the figure of 8 plastic strip to join to the gutter and this is cut into lengths to fit between the clamps of the roof rack, don't know what the others do :wink:
simon hall
Post by simon hall »
A few of us down here have them and we just through it over the top, attach it to the roof rack, bumpers etc and when the wind is to much, dont have it attached at all as it keeps you awake all night flapping around!
Come follow the dream!
vwbuzzers
Post by vwbuzzers »
I'm with simon i use bungees and rope over the roof it's the only real way to stops these things falling off/ flapping about
Dog
Post by Dog »
I use 4 clamps... 2 at the very ends, 1 just before either door, so I can still open them... Why do those wing nuts hurt your fingers so much! Really have to crank them up tight or it falls off with the wind. If done right will stay on all week...
I used to be indecisive, but now I'm not so sure...
