Bulk Buy - BMD Serpentine Pulleys.
Dipsy
Post by Dipsy »
Guys and Galls,
I'm thinking of another bulk purchase by approaching BMD about thier Serpentine Pulley systems, so I just thought I'd try and get a rough idea of numbers before I contact them.
http://www.bmdpulleys.com/index.html
Anyone fancy one?
Nige
'El <ex> Presidente'
kev mc
Post by kev mc »
mmm maybe :!:
visit us on facebook southcoast wagenwerks
Eternal Optimist
Post by Eternal Optimist »
Yep, interested.
outoftheblueintothenight
Post by outoftheblueintothenight »
yep could be up for this!
Lets park and up and have a BEER!
686 bus-boy
Post by 686 bus-boy »
I ordered this - http://www.thesamba.com/vw/classifieds/ ... ?id=503468 - maybe you could try them, it cost me £104 shipped,was only about 2 weeks ago i ordered it so havent recieved it yet.
Slippers
Post by Slippers »
I would be interested.
ronnie12342003
Post by ronnie12342003 »
and me ta :D
sausage fingers
Post by sausage fingers »
Hi all. Just one slight issue.
I am talking about the point where the bottom pulley fits into the engine casing. The shaft of the pulley, not the diameter where the belt fits.
The bottom pulley on these are made to fit in the engine in the EXACT same size as an original pulley.
If you have a Remtec or Vege they may have been very slightly over-bored and a slightly oversized pulley fitted.
I bought a solid Scat pulley and had it CNC lathed to match my Wolfie Slotmag Wheels. After fitting it I discovered this problem. It caused the belt to twist and almost come off and the oil to come out in a fine mist and spray all around the engine bay. When I called Remtec they informed me that "quite often the hole is slightly egg shaped " so they ream them out to a perfect circle again and have about 4 different sized pulleys.
It may be worth checking your hole ( fnar fnar ) :roll: before you order one.
Neil :D
Dipsy
Post by Dipsy »
sausage fingers wrote:Hi all. Just one slight issue.
Neil :D
That's useful to know - It might explain the problems that some folks on Volksmoan have been experiencing.
Nige
Gnarly
Post by Gnarly »
Already got one, thanks for asking though :wink:
The bitter taste of poor quality lasts long after the sweetness of low price has been forgotten
Dipsy
Post by Dipsy »
Gnarly wrote:Already got one, thanks for asking though :wink:
Don't you want another one?
Seriously, what's your opinion on them?
Nige
ade700
Post by ade700 »
I'm being dim here buts whats the benefit of using these :?:
RUTLAND HARDCORE CAMPING POSSE '05/06,06/07,07/08,08/09
viccyfarm hardcore camping posse 09/10 10/11
cyw 1+2
COWIN BUS YEDS
Gnarly
Post by Gnarly »
ade700 wrote:I'm being dim here buts whats the benefit of using these :?:
The benefits are supposedly that it runs quieter, the belt is a modern vee type and its easy to adjust and fit a new belt
kev mc
Post by kev mc »
supposedly less drag from the belt also.
Gnarly
Post by Gnarly »
My thoughts on the kit:
Well made kit
Fast to send it out,
Works well once all fitted and it is quieter than the original setup
Very easy to adjust/tension the belt, also a doddle to swap
Had the sand seal kit added and it makes it damn snug, ask VWJim! Having said that though, think it is worthwhile to consider this option
Also, if you are doing a bulkbuy, might be worthordering a load of belts, poss for the shop as they are considerably cheaper than the price charged over here
BMD were great to deal with
It's a pain to fit for the following reasons
1) nub on the alternator needs taking off
2) Big pulley is damn tight with sand seal so if you need to take it off it takes a while and because its billet its not easy to lever
3) Again because of the sand seal, tapping the big pulley home was hard as wel
4) There is no way to lock the top pulley, so tightening the locking nut is tricky, and means several checks over the first weeks
I haven't put enough miles on it to comment on long term, but so far i'm happy with it, now i've got over the fitting issues :wink:
