Vehicle of Historic Interest (VHI) definition
John TC
Post by John TC »
The UK's Department for Transport has released the long-awaited definition of a Vehicle of Historic Interest (VHI), which will define the classics that will be exempt for taking an MOT test.
Crucially, it also defines how modified classic vehicles should be dealt with.
The basic outcome is that most vehicles manufactured or first registered over 40 years ago will (from 20 May 2018) be exempt from needing an MOT – but owners will still be able to have their vehicles MOT'd if they wish to, and they won't be forced to register their vehicles as a VHI (Vehicle of Historic Interest).
Vehicles that were modified in period – including specials – will be allowed to be registered as VHIs, and will therefore be exempt from the need for an MoT as well.
Vehicles that have been modified in the last 30 years will not be eligible to be registered as a VHI, but will simply need to be MOT'd each year, as they are currently. This is a rolling 30-year date, to protect classics that are currently being modified, or that may be modified in the future.
However, modifications that improve 'the efficiency, safety, preservation or environmental performance' of a vehicle, such as uprated brakes or electronic ignition, will not prevent the vehicle from being granted VHI status.
There were widespread fears that modified vehicles in particular were to be legislated off the road, but this has not been the case.
This is largely thanks to the work done by the Federation of British Historic Vehicle Clubs with the Department for Transport – a statement from the Federation says that, 'The FBHVC wishes to express its appreciation of the open and collaborative manner in which the DfT approached these discussions.'
Important points from the FBHVC
The process is one of self-declaration.
Owners will only be required to declare their vehicle to be a VHI if they wish to be exempted from an annual MoT Test.
All vehicles will still be able to be tested if their owners wish.
The criteria are generic and permit changes made, less than 30 years prior to the declaration, which improve efficiency, safety, preservation or environmental performance.
Those vehicles registered on a Q plate, as kits or built up classics are not entitled to be declared as VHIs until 40 years after they were registered.
For motorcycles only the criteria of Q plates, kits and built-up classics prevent declaration as a VHI.
The Guidance refers to 'a marque or historic vehicle experts'. A list will be published on the website of the Federation of British Historic Vehicle Clubs by 30 April 2018. Vehicle owners wishing to confirm if they may declare their vehicle as a VHI, may choose to contact the appropriate nominee from this list.
The new legislation will come into effect from 20 May 2018.
Department for Transport's guidance on Vehicles of Historical Interest (VHI)
These are the notes, in full, released by the Department for Transport:
Most vehicles manufactured or first registered over 40 years ago will, as of 20 May
2018, be exempt from periodic testing unless they have been substantially changed.
Large goods vehicles (ie goods vehicles with a maximum laden weight of more than
3.5 tonnes) and buses (ie vehicles with eight or more seats) that are used commercially
will not be exempted from periodic testing at 40 years.
A vehicle that has been substantially changed within the previous 30 years will have
to be submitted for annual MoT testing. Whether a substantially changed vehicle
requires re-registration is a separate process.
Keepers of VHIs exempt from periodic testing continue to be responsible for their
vehicle’s roadworthiness. Keepers of vehicles over 40 years old can voluntarily
submit vehicles for testing.
Keepers of VHIs claiming an exemption from the MoT test should make a declaration
when renewing their vehicle tax. The responsibility to ensure the declared vehicle is
a VHI and meets the criteria, rests with the vehicle keeper as part of their due
diligence. If a vehicle keeper is not sure of the status of a vehicle, they can consult
a marque or historic vehicles expert, a list of whom will be available on the website of
the Federation of British Historic Vehicle Clubs.
If a vehicle keeper cannot determine that the vehicle has not been substantially
changed, they should not claim an exemption from the MOT test.
The criteria for substantial change
A vehicle will be considered substantially changed if the technical characteristics of
the main components have changed in the previous 30 years, unless the changes
fall into specific categories. These main components for vehicles, other than
motorcycles, are:
Chassis (replacements of the same pattern as the original are not considered a
substantial change) or Monocoque bodyshell including any sub-frames
(replacements of the same pattern as the original are not considered a substantial
change);
Axles and running gear – alteration of the type and or method of suspension or
steering constitutes a substantial change;
Engine – alternative cubic capacities of the same basic engine and alternative
original equipment engines are not considered a substantial change. If the number
of cylinders in an engine is different from the original, it is likely to be, but not
necessarily, the case that the current engine is not alternative original equipment.
The following are considered acceptable (not substantial) changes if they fall into
these specific categories:
Changes that are made to preserve a vehicle, which in all cases must be when
original type parts are no longer reasonably available;
Changes of a type, that can be demonstrated to have been made when
vehicles of the type were in production or in general use (within ten years of
the end of production);
In respect of axles and running gear changes made to improve efficiency,
safety or environmental performance;
In respect of vehicles that have been commercial vehicles, changes which can
be demonstrated were being made when they were used commercially.
In addition if a vehicle (including a motorcycle):
Has been issued with a registration number with a ‘Q’ prefix; or
Is a kit car assembled from components from different makes and model of
vehicle; or
Is a reconstructed classic vehicle as defined by DVLA guidance; or
Is a kit conversion, where a kit of new parts is added to an existing vehicle, or
old parts are added to a kit of a manufactured body, chassis or monocoque
bodyshell changing the general appearance of the vehicle;
it will be considered to have been substantially changed and will not be exempt
from MOT testing.
However if any of the four above types of vehicle is taxed as an 'historic vehicle' and
has not been modified during the previous 30 years, it can be considered as a VHI.
This guidance is only intended to determine the testing position of a
substantially changed vehicle, not its registration.
How to declare a vehicle for the 40 year MOT exemption
Vehicle keepers are required to ensure that their vehicles are taxed when used on a
public road. From 20 May 2018, at the point of taxing a vehicle, the vehicle keeper
can declare their vehicle exempt from MOT if it was constructed more than 40 years
ago.
When declaring an exemption, you will be required to confirm that it has not been
substantially changed (as defined in this guidance). This process will be applied to
pre-1960 registered vehicles, as well as newer vehicles in the historic vehicle tax
class.
If the vehicle does not have an MOT and you wish to continue using it on the public
roads, you will have either to undergo an MOT or, if you wish exemption from the
MOT, to declare that the vehicle is a VHI.
If the vehicle has a current MOT certificate but you anticipate that on expiry of that
certificate you will wish exemption from future MOTs you will at the time of
relicensing be required to declare that the vehicle is a VHI.
How to tax your vehicle in the historic vehicle tax class
Where vehicle keepers first apply for the historic vehicle tax class, it must be done at
a Post Office. If you are declaring that your vehicle is exempt from MOT, you will
need to complete a V112 declaration form, taking into consideration the substantially
changed guidelines, (as defined above). Further re-licensing applications, including
making subsequent declarations that the vehicle does not require an MOT, can be
completed online.
Further advice on taxing in the historic vehicle tax class can be found here.
What do I need to do if I am responsible for a vehicle aged more than 40 years old and first registered in or after 1960?
From 20 May 2018 most of these vehicles will not need a valid MOT certificate to be
used on public roads. You still need to keep the vehicle in a roadworthy condition
and can voluntarily have a test. We recommend continued regular maintenance and
checks of the vehicle.
You need to check whether the vehicle has been substantially altered in the last 30
years, checking against the criteria (in the guidance above). If it has been altered
substantially a valid MOT certificate will continue to be required. If you are unsure
check, for example from an expert on historic vehicles (list referenced in the
guidance). If you buy a vehicle, we also recommend checking with the previous
owner if you can.
The registration number of a vehicle should not be used to determine if the vehicle is
a VHI as it may not reflect the vehicle’s age (cherished transfers, reconstructed
classic vehicles etc.) The registration certificate (V5C) is more authoritative, but
there are specific cases for example related to imported vehicles where in some
cases the age of the vehicle would not have been captured at point of registration.
If your vehicle does not have a current MOT certificate and is exempt from needing
an MOT test you will need to declare this each time when you apply for Vehicle
Excise Duty.
For large vehicles, see also the later sections.
What do I need to do if I am responsible for a vehicle first registered before 1960?
These vehicles are currently exempt from the requirement for a valid MOT certificate
to be used on public roads. Most, but not all, will continue to be exempt. You still
need to keep the vehicle in a roadworthy condition and can voluntarily have a test.
We recommend continued regular maintenance and checks of the vehicle.
You need to check whether the vehicle has been substantially altered within the last
30 years checking against the criteria (in the guidance notes). If it has been
substantially changed, an MOT certificate will be required for its use on public roads
from 20th May 2018, even if the vehicle has previously not required an MOT.
If your vehicle does not have a current MOT test certificate and is exempt from
needing an MOT test you will need to declare this each time when you apply for
Vehicle Excise Duty.
If you are responsible for a large goods vehicle (more than 3.5 tonnes) or a public
service vehicle (with 8 or more passenger seats) used commercially, you will require
a valid test certificate if the vehicle has been substantially changed in the last 30
years or if, in the case of a goods vehicle, it is used when laden or towing a trailer.
Which old, large vehicles do not require testing from 20 May 2018?
Buses and other public service vehicles with 8 or more seats that are used
commercially are exempt if they are pre-1960 vehicles. This is still the case from 20
May 2018 unless they have been substantially changed.
Buses that are not public service vehicles over 40 years old are exempt from 20th
May 2018 if they meet the new definition of “vehicle of historical interest”.
Large goods vehicles (of more than 3.5 tonnes) are exempt from testing, if first used
before 1960 and used unladen, but provided (with effect from 20th May 2018) they
have not have been substantially changed.
A small number of pre-1960 large goods vehicles will require goods vehicle tests. If
they have never been tested, owners will need to apply for a first test using a VTG1
application form. This includes contact details for DVSA, which can be used in the
event of practical problems, for example concerns about testability and finding a test
centre.
Some separate exemptions from testing in full or parts of the test are relevant to
some old, large goods vehicles. For example steam powered vehicles are exempt
from testing. Another example is in respect of the petrol driven historic lorries, all
spark ignition (petrol) vehicles over 3.5 tonnes are exempt from a metered check in
the test.
------------------------------1956 RHD Kombi.------------------------------
viewtopic.php?f=8&t=82512
---------------------------------Aka Bucket-----------------------------------
David Eccles
Re: Vehicle of Historic Interest (VHI) definition
Post by David Eccles »
Thanks for posting this .. it clears up and lays to bed rumours and fears
PS and Merry Christmas John!
David
Drive your bus; enjoy your bus
Post by flatbeat »
Well done John :D I don't know if it was coincidence but it seemed a lot of IRS'd modded buses came on the market when the rumours started....be interesting to see if they're no longer for sale now we have a definitive answer :lol:
Merry Christmas :D
thebouncingbunny
Post by thebouncingbunny »
So the way I read it irsd vans would be substantially modified? Unless the fact that the gearbox is beetle based and of a type available back in the day......
As for steering that gets a mention.soooo that creative rack and pinion set up this would be substantial modification or safety upgrade.
Tho a bit clearer it seems slightly complicated and bound to end in tears
Post by flatbeat »
Anything that improves safety or reduces emissions is ok and doesn't change the status. My 15w would be fine with brakes, rack and IRS but the turbo lump blows it...so to speak :lol:
The main concern I think for most was the possibility of losing age related plates and being given Q plates and that isn't going to happen so all good :D
mclarni
Post by mclarni »
The way I read that is that anything with a Red 9 design type front end will be considered “substantially modified” due to the fact that the suspension and steering are no longer the same “type” as were originally fitted.
“Axles and running gear – alteration of the type and or method of suspension or
steering constitutes a substantial change;”
VOTM August 2012 :)
THE MARMITE BUS
viewtopic.php?t=47958
mclarni wrote:
Wed Dec 20, 2017 7:55 am
Yep, I think IRS, SA, steering box raised, narrowed beams, notched chassis, dropped spindles etc should all fall into that as well, as they're not safety improvements.
Glad to see mod's for safety are allowed, and the clarification doesn't effect age related number plates. So it's carry on as you were getting MOT's. Which at the end of the day is the sensible thing to do whether stock or modified.
So a modded bus (IRS, rack, 1776, dropped etc) which is already on an age related plate just needs to get an MOT every year and carry on as usual ?
JonnyCJ wrote:
Thu Dec 21, 2017 6:12 pm
Thankfully, yes. I believe so.
Fab - whilst it would have been do-able to put my bus back to stock, I do love how it is after 4 years of getting it how I wanted. Having a Q plate would have taken the icing off the cake.
Had stored up some big nut RGBs and a gearbox in case the worst happened but looks like they may be up for sale soon !
:cheers: :cheers:
susta
Post by susta »
Thanks John, Hope you and the family had a Good Christmas. But feel from what you have and others said on various sites they have just stepped back and realised their initial objectives were not enforceable , so have wriggled out with the safety and improvement options, for now that is
