winter storage warmth
mikey52
Post by mikey52 »
hi
I am having to put my splitscreen under a loose cover for the winter is it a good idea to put a small greenhouse heater (mains electric type ) in the van to keep cosy or does this cause other problems
thanks mike
Bugzy Malone
Re: winter storage warmth
Post by Bugzy Malone »
I wondered if the same for my Elise. Decided no point, so it's just on a maintenance charger with a moisture zapper thing in it. Much cheaper than heating your garden :p
The 200quid SO42 from Alaska!
viewtopic.php?f=2&t=79284
Old skl Testament. john, chapter 5 verse 3.
"and Jesus said to his disciples,
air cooled rocks"
then they ate fish and partied
Hongkongphooey
Post by Hongkongphooey »
Cold and dry is what you want, if it is a loose cover then it should be able to breath ok as there will always be some moisture in the air so if you introduce any warmth (Heater) under a nice dark cover you will probably end up with a furry mouldy interior very quickly...
'60 RHD Devon
susta
Post by susta »
12volt dehumidifier run off a solar panel
Aspro
Post by Aspro »
What? It would probably cost less to store it in a proper facility then to run an electric heater day and night.
Plus heat inside cold outside will create major condensation issues.
Don't do it.
Open up the windows a tad and let it all breath
As above. Or even better, just use it....
BusBug&KG
Post by BusBug&KG »
WHS
