4 Post Lift - Storing a bus underneath
westwopa
Post by westwopa » Fri May 08, 2015 9:01 pm
Looking into storage options in which I will need to store a car above a stock height bus, been considering a four post lift/ramp but struggling to find one with sufficient height. Does anyone know of any manufactures which give ~2m high clearance?
And no I don't want to lower the bus, let air out of the tyres..... :roll:
lee c
Re: 4 Post Lift - Storing a bus underneath
Post by lee c » Sat May 09, 2015 6:41 am
I've got a catalog at work wth loads of different ramps in, I'll have a look for you!!!!
MarkFer
Post by MarkFer » Mon May 11, 2015 10:00 am
Couple of suppliers here, depends on how much you want to spend!
http://www.garage-apparatuur.com/parkee ... engels.htm
http://hamercarlift.com/
thesickness
Post by thesickness » Mon May 11, 2015 11:47 am
store the bus up top? #statetheobvious
Post by e m p i » Tue May 12, 2015 8:19 am
I would be concerned about the lift creeping down. Having worked in a place with 3x four post lifts they all tended to creep down a foot or so over night if you're going to store a car wtc underneath the a couple of 7' axle stands under the lift are a must.
Cheers, Lee.
thesickness
Post by thesickness » Tue May 12, 2015 11:54 am
e m p i wrote:I would be concerned about the lift creeping down. Having worked in a place with 3x four post lifts they all tended to creep down a foot or so over night if you're going to store a car wtc underneath the a couple of 7' axle stands under the lift are a must.
Cheers, Lee.
Never seen that, they lock out don't they, drop it down after the click...
split999
Post by split999 » Tue May 12, 2015 6:09 pm
Cheers, Lee.
Yep. Mandatory.
66 UK RHD 11
70 911 Coupé
59 NSU Prima III KL
Post by e m p i » Tue May 12, 2015 8:08 pm
I was going back about 25 years to be honest :lol: Or maybe we just had a duff lift is more likely :roll:
Cheers, Lee.
55bdkombi
Post by 55bdkombi » Mon May 18, 2015 9:50 am
I have a Bradbury 4 post here in work. It goes as high as you would really ever need it to go in terms of working on cars, my bus won't go under with the flaps removed off the ramp.
http://www.barnwest.com/
54 barndoor singlecab
67 fastback 1600tl
