Adding a turbo
dave3lions
Adding a turbo
Post by dave3lions »
This is on my list of things to do so I'm curious as to the general consensus for adding a turbo. I imagine it's frowned upon by many, but have you done it, would you recommend it or is it an absolute no no and it all went boom?
A quick google search brought up these guys http://www.vwturbokits.com
My bus is running a 1600 twin port Beetle engine. I'm not looking for F1 performance, just a little "wolf in sheep's clothing".
Thoughts please?
Thanks, David.
NikC
Location: Mayrhofen, Austria (but my for sale bits are in the UK)
Re: Adding a turbo
Post by NikC »
Are you on facebook, Brian Galpin has puts lots of pics and info on his turbo job in the facebook group.
Cornwall to Austria in my 1961 15 Window Story
The Westy Resto
_____________________________
1961 15 Window Deluxe Microbus
1967 SO42 Westfalia
1956 US export spec Beetle
1970 Type 3 Notchback
dave3lions
Re: Adding a turbo
Sure am. I'll head over there and link to this thread. Thanks.
tufty65
Re: Adding a turbo
Post by tufty65 »
You'd be better off just updating the motor to something a little bigger.
You could just slap a turbo set up on it (it's been done) but to do it properly you need to think about balancing the bottom end, lowering compression etc etc as these old standard motors don't like being revved much past 5k and with a turbo on boost you'll be revving a lot more than that!
There is nothing stopping you from putting a turbo on but I wouldn't expect a standard 1600 to take abuse for long.
Be careful power can be addictive !!
OFF 35
Et 12.64@106.25
http://www.offdrc.co.uk/
modifiedbrian
Re: Adding a turbo
Post by modifiedbrian »
My thoughts exactly Simon.
2276cc fuel injected turbo 1967 SO42
Best ET 14.66
YOUR ONLY SUPPOSE TO BLOW THE BLOODY DOORS OFF !!!!
Re: Adding a turbo
Post by flatbeat »
Wouldn't want to bolt one of those kits to stock 1600 tp.
mclarni
Re: Adding a turbo
Post by mclarni »
I am building an engine with a turbo at the moment. It will be 1776 or more though using the Renault 5 turbo set up and a VW speedshop header.
I'm aiming for a good pulling motor, not a racer. Will be keeping standard weight flywheel, 69mm crank etc and balancing up bottom end of engine.
I've had a lot of turbo cars in the past and know my way around them. Should be good fun building an aircooled turbo lump.
I know that VWGillyBilly had a decent kit on a 1600 on his Samba using the Renault 5 turbo set up. That was running about 10psi of boost and was achieving 130bhp. It wasn't a standard 1600 and had been "built" with the intention of fitting the turbo kit.
VOTM August 2012 :)
THE MARMITE BUS
viewtopic.php?t=47958
