Builder types
If it's not about Vans, Dubs, Air-cooled - you guessed it - it goes in here.
mjknight71
Builder types
Post by mjknight71 » Sat May 11, 2019 8:51 am
Two single garages in a block of two garages, single block walls, rear wall retaining garden about 1m high.
Does the separating wall between the garages offer strength to the rear retaining wall?
So can I knock in partition wall down to make a double?......not bother about issues with roof etc.
Any thoughts
Re: Builder types
Post by 8 8US » Sun May 12, 2019 11:06 am
Is the roof supported on the middle wall?
Almost certainly the wall is providing lateral support to the rear retaining wall, although you may be able to provide the same support with a buttress, for piece of mind I’d get a structural engineer to take a look.
mjknight71
Re: Builder types
Post by mjknight71 » Wed May 15, 2019 9:40 am
cheers, i assumed the center wall would be providing support. Just wanted to see others thoughts who might have some knowledge rather than my assumption.
simono
Re: Builder types
Post by simono » Thu May 30, 2019 11:56 am
On a single skin wall without major openings its' maximum span is 3m centres. Building regs A/D a. I was an architectural technician.
