Type 1 heads aren't really CC specific. You need to look at the bore size and then order them or have them machined for that.
SSP or VW speedshop can help you there and mildly uprated ones are not too badly priced.
As for carb's well you will find there is lot's of opinion's available. The stock jetted one is IMHO too small for what you have though. I'd be looking for a set of Twin 40 DRLA's to run that engine. Maybe 36's if you can find them. See Euro Carb on the internet, they do reconditioned/new ones.
Ultimately, if you want to go quickly a IRS or straight axle conversion is needed. If you just want to cruise, you can still do so with a diff upgrade to the current set up. If you do go down the conversion route, you will end up lowering it at the same time, so you will need to to lower the front to match.
There is also a ideal rpm to keep the engine cool, above it you can cause it to overheat. That then opens up more option's to address it.
Oh and then there's brakes to stop you!!. It can add up.
For me, I'd address the engine problems with the future upgrades in mind, keep the speed down and get saving!!
_________________ "It's rust Jim, but not as we know it"
