It is currently Thu Jun 20, 2013 4:59 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Engine fitting
PostPosted: Fri May 22, 2009 1:56 pm
Offline
To fit a a bigger engine (2276) in my 55,non barndoor, will the engine bay need to be widened,if so by how much
cheers
Andy
Top
 Profile
 Post subject: Re: Engine fitting
PostPosted: Sun May 24, 2009 8:29 pm
Offline
Nope. The engine shouldn't be significantly larger externally. It'll just be carbs, exhausts, fuel pipe and oil coolers which give you the fitting issues.
Top
 Profile
PostPosted: Tue May 26, 2009 10:40 pm
Offline
Founder BWA Member
Founder BWA Member
As Bobley said, unlikely as long as really long con rods haven't been used
_________________
2014 B.D.A...
Image Image
Supplying quality parts from SCAT, Kennedy Clutches, CB Performance & FIRETEC. Plus in house designed items. Also fitting service including modifications & mechanical upgrades.
Top
 Profile
Display posts from previous:  Sort by
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
