It is currently Fri Jul 30, 2010 2:37 am
Post new topic Reply to topic  [ 12 posts ]
Author Message
 Post subject: 2276efi turbo readvertised due to timewaster, priced to sell
PostPosted: Tue May 19, 2009 11:29 am
Offline
had the engine provisionally sold over weekend only for them to pull out today
so up it goes again and priced to sell !!!
vw speedshop built 2276 fuel injected turbo built around two years ago but with less than 2000 miles on it, was run in, in a detuned state but has now paid a visit to raceshack and is making just under 250bhp AT THE WHEELS with only 1 bar on the turbo
its got alot more in there to come but has been left like this to be fully streetable and reliable!!!
On the run back from raceshack the temp stayed at 97 all the way home even when it was blipped
The raceshack bill came to over 2k as the ecu was playing up so a brand new omex has been fitted together with wiring loom etc and the engine has been gone through to make sure the condition is A1 which it is
I no with the market as it is I"m gonna have to take a hit so I"m asking 7500 which is no where near what I believe its worth and for raceshack to build this you would be looking at 12 to 14k so its there for someone to grab a bargain!!!
Will be at vanjamboree this weekend for anyone to view or contact me anytime for anymore details 07866494683
if required the IRS rancho pro comp box will be available at 1750 with the engine or available after the engine has sold
will post a pic later on this thread
Top
 Profile
 Post subject: Re: 2276efi turbo readvertised due to timewaster, priced to sell
PostPosted: Tue May 19, 2009 11:54 am
Offline
Forgot to say will swop with money coming back my way for a proffesional newly built 1914/2007 or simuler either turn key or long block with no miles or low miles in it, don"t want out and out race motor just a nice torquey plodder of an engine :D ( MUST BE GETTING OLD :D )
Have been doing my research and no what these kinda engines go for so please be sensable :D
thanks again
paul
Top
 Profile
PostPosted: Wed May 20, 2009 1:20 pm
Offline
Crankcase: CB Ally Race case
Crankcase fittings:
Case hardware and fitting kit
Gasket and Seals:
Elring gasket set and silicon crank seal
Crankshaft: CB 82mm forged
Crank Fitting Kit: Crank Fitting Kit
Barrel and Piston Kit: Mahle 94mm Stroker kit
Conrods: CB H Beams
Cylinder Heads: 044 CNC Mini Wedge 42 x 37
Copper Head Gaskets: 1.5mm
Flywheel: Chromoly 13lb flywheel 8 dowel
Cylinder Studs: Chromoly 8mm studs
Gland Nut: Chromoly 38mm Gland Nut
Bearing Kit: Main Bigend and DT cam bearings
Engle FK8(1.4 rockers)
Cam Gear: CB Straightcut steel
Cam Followers: Scat Lightweight
Pushrods: Manton chromoly
Rockers: CB Pro 1.4 rocker set Rocker Shaft:
End play shims and dowel pins
Pushrod Tubes: Jaycee-
Dynamic Balancing: Crank Flywheel Clutch Clutch:
Kennedy stage 2
Clutch Centre Plate:
Daiken HD
SUMP PLATE: Billet ally plate w drain
Cylinder Deflectors: Deflectors for 8mm
Deep Sump: Empi 3.5 Quart Sump
Garret t3/4 turbo with stainless header.
Top
 Profile
PostPosted: Wed May 20, 2009 6:08 pm
Offline
Founder BWA Member
8)
You might be getting a call from a guy I know, and he's got a real nice 1776 you might be interested in... I've told him if he buys it, and the gearbox, I'll fit it for free.... (If I had the spare pennies, I'd have that without a second thought!)
_________________
Supplying quality parts from SCAT, Kennedy Clutches, CB Performance & FIRETEC. Plus in house designed items. Also fitting service including modifications & mechanical upgrades.
Top
 Profile
PostPosted: Wed May 20, 2009 6:31 pm
Offline
Thats cool jim :D
thanks mate
Top
 Profile
PostPosted: Wed May 20, 2009 6:35 pm
Offline
Founder BWA Member
No worries. We were talking through the options so long, battery died.... :oops:
_________________
Top
 Profile
PostPosted: Fri May 22, 2009 9:20 am
Offline
:D
Got the pm from your mate jim and have pm"d him back as may be interested but just depends how much he is asking for the 1776 ?
I"m at vanjammboree at newark this weekend so be better to call (07866494683 )
Anyone wishing to see it I will be on the brads cancer foundation stand :D
Top
 Profile
PostPosted: Tue May 26, 2009 10:42 pm
Offline
Founder BWA Member
New BWA bus on the way....
_________________
Top
 Profile
PostPosted: Wed May 27, 2009 7:34 am
Offline
Bugjam ? :lol:
_________________
RHD '63 13 window deluxe 2276 FI turbocharged & chargecooled 323.3bhp 135.9mph @7150rpm :-)
Mk1 Escort Mexico 168.5 bhp
Top
 Profile
PostPosted: Wed May 27, 2009 8:46 pm
Offline
Founder BWA Member
Easily by then....
_________________
Top
 Profile
PostPosted: Wed May 27, 2009 9:36 pm
Offline
Jim
gonna drop the engine and gearbox out tommorrow/friday so will be up for bringing it over early next week if thats okay with you and trevor ?
can you pm me your address and postcode and poss your phone number ?
Gutted mate but heh, thats life LOL
But will be great to see how far trev takes it
Top
 Profile
PostPosted: Wed May 27, 2009 10:24 pm
Offline
Founder BWA Member
On it's way.
_________________
Top
 Profile
Display posts from previous:  Sort by
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
